91 hatch black paint 3 yrs old
red and black int
powerdyne supercharged
cobra intake
70 mm t body
76mm mass air
30 lbs inj
msd ingnition
6btm box
areo motive reg
40k on rebuilt 302
heads wear just totaly gone threw and o ringed
this motor was ran with stock trime with intake up to 5000 miles ago then cam the blower new cam heads injectors and a hole bunch more
the car has a 6 pt roll bar in it
has a rebuilt 5 spd new clutch
aluminum d shaft 31 spline axles aburn pro posi 373 gears
im also selling with this car a 308 set up cat h beam rods dss crank dss pro lite pistions rings bearings probe main suport arp studs ford racing oil pump anderson motor sport b41 blower cam and matched springs and more im getting totally out of mustangs and this package needs to go over 13000 invested im sure ive forgot some stuff and it is all gooing 10,500this is a fast car i will email pics if intrested will not deliver u must pic up u wount be disapionted do what the price is only going to go up in the spring
Discussion Starter · #2 ·
spring is just around the bend !
