people that already know system design and theory of operation, are telling you what to test for
no one is beside you to tell you what to connect and how, THAT IS UP TO YOU TO DO
YOU NEED WIRING DIAGRAMS IN FRONT OF YOU, YOU WANT TO LEARN, BUY THEM
NOBODY CAN DO THIS WITHOUT THEM
sounds like you want to fix your car, with this ‘simple’ fix from the internet
PEOPLE MAKE A LIVING. fixing cars like yours, you are the one that decided you want to fix, without any prior knowledge, how did you think it was going to turn out?
AND STOP WITH THE, ‘I DONT UNDERSTAND IT WAS RUNNING FINE ONE MINUTE THEN THE NEXT NOT’
all things work UNTIL THEY DONT
so shall we stop with diagnosis?
sounds like you are a quitter
"PEOPLE MAKE A LIVING. fixing cars like yours, you are the one that decided you want to fix, without any prior knowledge, how did you think it was going to turn out?"
And there we have it, folks. Of course it's not going to turn out well. I guess my mistake was trying to fix it myself and asking people on the internet for advice.
Quite frankly, I don't even know how to read a wiring diagram and interpret that based on what's on the car. I've looked up schematics from past threads on forums and I don't know where to start. Every piece of literature on this topic is geared toward someone who already has a basic understanding of these systems.
I do have the wiring diagrams.
What does it mean to connect the DMM sensor between the EGO signal wire and the negative battery terminal? Between? Like where exactly? That seems like a lot of wiring, am I supposed to just pierce the wire insulation with the voltmeter somewhere between the battery terminal and the signal wire? What is the difference between an EGO and a HEGO as it pertains to this test? Do you see why I'm asking for help on how to do this? If I could read wiring diagrams and perform these tests, do you really think I'd be here asking for help?
Picture me as someone who doesn't know the first thing about any of this. You really think I'm going to be able to just look at this and perform those tests correctly? No, I'm going to be taking shots in the dark. That's why I'm asking for input - I want to perform these tests correctly so I'm not wasting my time and everyone else's time.
Aren't you the one who was giving me **** about performing superfluous tests? Like how you said no one asked me to unplug the IAC with the engine warm? When I performed that test, I did it in a way that made sense based on what I had read online and in the Haynes manual. And you came on here giving me **** for doing it incorrectly. So now I'm asking for clarification on how to do the tests and you're telling me to just figure it out? Not sure what the thought process is here.
"No one is beside you to tell you what to connect and how, THAT IS UP TO YOU TO DO"
So I'm supposed to just know this **** huh? Just like magic? I'm not asking you to fly down here and do the tests for me, dude.
This is starting to seem a lot more like gatekeeping than helping diagnose the issue.
So, in sum, we have no real theories about what is causing the issue. If I'm understanding the earlier posts correctly, haven't we ruled out the 02 sensors by the fact that I unplugged the battery and cleared the computer, and it's still having the problem exactly the same as before? Something about long term fuel trims?
I spoke to one of the techs at Steeda (they're local to me). He said it's almost definitely not the O2 sensor. He thinks it's an issue with the distributor or spark. Which doesn't make much sense either, since I've had two TFIs and one distributor go bad, and these symptoms I'm having now aren't even close to what I experienced with those failed parts.
