I have had my 1990 mustang GT for about a year and have always had an issue with it cutting power and bucking only when it is at 2500-3000RPM. It is a 5.0 AOD car with speed density. I have changed my map sensor, removed and blocked my EGR, replaced my fuel pump and filter, replaced the distributer, cap, and rotor, spark plugs, wires, ignition coil, and ran the codes. Most of these parts needed to be replaced anyways as they were original. The issue I have been having is that once the car reaches 2500 RPM it cuts power and jerks, bucks, and backfires forward until it reaches 3000RPM then it gets back into power. Once it downshifts and gets above that 3000RPM mark it pulls hard and feels as though nothing is wrong it literally only has issues in between 2500-3000RPM. I have a feeling it is something electrical simply because it is only during that 500RPM range. There are two attached videos that show the issue I'm having. Please give me any advice you have so I don't keep spending money on parts that aren't necessary.
Video 1 Video 2
Video 1 Video 2
