1990 coupe project
3556 Views 23 Replies 6 Participants Last post by  Fox-you
9
Bought this coupe in December 2020. Had a ford racing 347 in it with a 3550 transmission. Managed to get 40 miles on it and it started knocking. Sounded like an old 7.3 🤦‍♂️.
Talked with the wife and a shop I know for building killer engines. $40,000 later, I have a ton of parts and still no running car. We'll get there.
Engine:
410 ci
351w stock block
4.040 x 4.000
K1 4340 forged crankshaft
K1 4340 forged h-beam rods
Weisco forged flat top pistons
Afr 220 heads with 58cc chambers
T&d 1.7 rockers
Morel solid lifters
Bullet racing solid roller cam (specs in picture)
Holley hi-ram efi intake manifold
Accufab 95mm throttle body
Haltech 2500 ecu
Haltech smart coils
Exhaust:
Stainless works 2" primary headers
3.5" dr gas x pipe
Drivetrain:
T56 magnum
Mcleod rxt clutch
Modern driveline hydraulic clutch kit
Quick performance fab 9" rear
4.56 gears on a spool
35 spline moser axles
Front suspension:
Upr chromoly k member and a-arms
Strange adjustable struts
Upr coilover kit
Flaming river manual rack
Upr bump steer kit
AJE 2" drop spindles
Rear suspension:
Upr pro series control arms
Viking double adjustable coilovers
Merillat torque boxes
Trz anti-roll bar
Brakes:
Maximum motorsports manual conversion
93 cobra master cylinder
Wilwood drag front kit
Wilwood dynalite rear kit
Fuel system:
Aeromotive 15 gallon fuel cell
Aeromotive 340lphpump
-8 an ptfe feed and return lines
Ford racing 60lb injectors
Motor vehicle Automotive fuel system Automotive exterior Gas Auto part
Automotive tire Hood Motor vehicle Bumper Electrical wiring
Gear Auto part Machine Fashion accessory Metal
Blue Toy Automotive tire Motor vehicle Wood
Wood Bumper Automotive exterior Machine Flooring
Font Handwriting Material property Rectangle Poster
Hand Automotive lighting Finger Silver Circle
Font Auto part Cylinder Metal Nickel
Tire Wheel Car Vehicle Automotive parking light
See less See more
  • Like
Reactions: 1
1 - 20 of 24 Posts
Nice parts. I hope you’re able to update the thread soon.
All progress on hold right now. September 4th im dropping the car off at Cage Rage Fabrication for torque boxes and through floor subframe connectors. Then ill be doing a full rotisserie sand blast, rust repair and paint job.
  • Like
Reactions: 1
Good luck with the build... this is why I preach to buy a "done" proven car with paperwork.
I've seen a few bulletproof streetable 4sec cars that you can eat off for 40k.
  • Like
Reactions: 1
The scary part is that it had over $15k in receipts from a shop that put it together. Not sure what happened with some of the mod choices tho. 347 with a 3550 trans and spec stage 3 clutch. Everything else was bone stock. Best guess is the guy beat the snot out of it.
  • Like
Reactions: 1
1076223
Rolling chassis now. Getting ready to drop her off at Cage Rage Fabrication for torque boxes and through floor subframe connectors
See less See more
She’ll be fabulous when done. Can’t wait to see the results on the thru floor connectors. :)
2
1076374
1076375
Loaded and ready to roll to Cage Rage this weekend!
See less See more
  • Like
Reactions: 1
2
Cage Rage killing it!!!! Looking awesome.
Tire Wheel Vehicle Car Automotive tire
Vehicle Automotive tire Wheel Motor vehicle Car
See less See more
  • Like
Reactions: 1
3
Cage Rage is all done and the car is home. The next step is getting a rotisserie here and blasting the whole car. Found some rust issues that need to be addressed.
Hood Motor vehicle Automotive tire Automotive design Automotive exterior
Vehicle Motor vehicle Gas Bumper Automotive exterior
Tire Wheel Motor vehicle Vehicle Automotive tire
See less See more
  • Like
Reactions: 1
Pardon me I’ve got to excuse myself. I’ve drooled so much I’ve got to change my shirt.
It has turned out to be a sweet looking pile of parts for sure.
This beast of an engine has finally made it home!! Going to be a while for any other updates as the chassis is going back for a ton of fab work early next year.
Automotive tire Motor vehicle Automotive design Bumper Automotive exterior
See less See more
Team Z had a Black Friday sale and I couldnt resist. Part of the the next round of fab will be rear shock relocation and mini tubs!
Wood Linens Pattern Art Flooring
See less See more
  • Like
Reactions: 1
8
With a little help from a friend, the test fit is complete. Now im itching to get this thing done!
Wheel Tire Hood Automotive tire Vehicle
Tire Land vehicle Wheel Vehicle Car
Wheel Tire Automotive tire Hood Tread
Car Vehicle Hood Motor vehicle Automotive tire
Automotive tire Hood Automotive lighting Motor vehicle Automotive design
Hood Motor vehicle Automotive tire Car Vehicle
Automotive tire Aircraft Tread Aviation Airplane
Automotive tire Motor vehicle Hood Vehicle Wheel
See less See more
  • Like
Reactions: 1
What hood will you run? All will fit under the hood? ty
2
It fits under the 4" cowl i have
Automotive tire Automotive lighting Automotive mirror Motor vehicle Automotive design
Wheel Tire Car Automotive tire Motor vehicle
See less See more
  • Like
Reactions: 3
the cool thing about that intake is that you could probably fab up a nasty ram air setup by tilting the radiator forward
years back i had a G8 Gt for my daily driver and ran an Australian OTR (over the radiator intake) although others make similar versions too
  • Like
Reactions: 1
1 - 20 of 24 Posts
