Hello, I'm currently looking for torque specs for my lower/upper intake, and heads. I'm currently running everything stock, stock intake, stock heads, the whole nine yards. I did however get my heads decked milled and shaved 30 thousandths of an inch to raise the compression. Would that change the spec rate any getting them shaved?
I’m no engine builder, so I don’t know if head-milling/increased CR may require adjusting the spec. ?? I'd also check the spec listed on the gasket you choose. Lastly – the stock head bolts are torque-to-yield, so they may be no-good/"used-up".
A quick search found this:
5.0L Torque Specs
Belhousing to engine bolts
28-38 ft/lbs
Camshaft sprocket bolt
40-45 ft/lbs
Camshaft thrust plate to engine block bolts
108-144 in/lbs
Crankshaft pulley to vibration damper bolts
35-50 ft/lbs
Cylinder head bolts
-1979-1992
--Step 1
55-65 ft/lbs
--Step 2
65-72 ft/lbs
-1993-up
--Step 1
25-35 ft/lbs
--Step 2
45-55 ft/lbs
--Step 3
75-85 ft/lbs
Differential shaft lock bolt
15-30 ft/lbs
Driveshaft U-joint to pinion flange bolts
70-95 ft/lbs
Exhaust manifold bolts
26-32 ft/lbs
Flywheel mounting bolts
75-85 ft/lbs
Front engine mount nuts
72-98 ft/lbs
Intake manifold to head bolts
--Step 1
96 in/lbs
--Step 2
16ft/lbs
--Step 3
23-25 ft/lbs
Intake manifold (upper intake to lower)
12-18 ft/lbs
Oil filter insert to engine block adapter bolt
20-30 ft/lbs
Oil pan mounting bolts
-1979
--Step 1 (Large bolts)
11-13 ft/lbs
--Step 1 (Short bolts)
7-9 ft/lbs
--Step 2 (Large Bolts)
15-17 ft/lbs
--Step 2 (Short Bolts)
10-12 ft/lbs
-1980 to 1987
9-11 ft/lbs
-1988 to 1993
6-9 ft/lbs
-1994-up
110-144 in/lbs
Oil pickup tube to main bearing cap nut
22-32 ft/lbs
Oil pickup tube to oil pump bolts
-1979 to 1987
10-15 ft/lbs
-1988-up
12-18 ft/lbs
Oil pump mounting bolts
22-32 ft/lbs
Pinion bearing preload
8-14 in/lbs
Pressure plate to flywheel bolts
12-24 ft/lbs
Rocker arm fulcrm bolts
18-25 ft/lbs
Spark plugs
7-14 ft/lbs
Timing chain cover bolts
12-18 ft/lbs
Vibration damper to crackshaft bolt
110-130 ft/lbs
Wheel lug nuts
85-105 ft/lbs
And search around for the proper pattern on the lower intake -- it's not intuitive.
