Year:1989
Make:Ford
Model:Mustang
Mileage:100000 M
Transmission:Manual
Engine:coyote 5.0 supercharged
Trim:lx coupe
1989 coupe roller , 2013 coyote 5.0 , Ford Racing supercharger (Whipple style) 6 speed manual . Very low miles on engine/trans/supercharger. (PICTURES COMING)
Car- 89 coupe with Skinny Kid race cars chrome-moly chassis , Mini tubs. Factory rear frame rails narrowed and plated with 1/2 inch steel plate. Fabricated 9 inch axle ,35 spline strange axles. (No center section) ladder bar suspension (can be converted to 4 link) 10.5 tire sits perfectly in wheel well. cars is very light and sits low and level. All sound deadener material has been removed from the car . Interior is out, have most interior. 1 aluminum Kerkey seat , Afco coil overs in rear. Trunk is sheet metal with dual battery mount , and fuel cell mount.
CAGE - is very extensive , probably 20 points. Sub frame connected thru floor pan with rectangle tube . Rockers/cage tied in to rectangle tube. Halo bar , bar behind dash, front sub frame connected to cage. Chassis and cage were $15,000
k-member is generic aftermarket tubular (UPR, or something similar) koni adjustable coil over struts.
included in sale Scott-Rod rear seat delete metal panel kit, and engine compartment inner fender/firewall kit
ENGINE- 2013 very low mile coyote (10,000 aprox) Ford Racing twin screw (TMR/whipple style ) supercharger with intercooler in cam valley (factory style)
package should be good for a conservative 650 HP. NO PCM OR HARNESS OR CONTROL PACK * (does have factory engine sensor harness ) 6 speed manual trans
Cage and trunk are bare metal need paint . Mini tubs have surface rust Car has small rust whole at bottom of drivers side fender. Front clip is off , can be bolted down for transport.
Original hood is there in primer .
I've owned the car for 30 years has been indoor stored the last 20 years
not a fire sale..... I would look at 73 or older TURN KEY corvette 71 OR OLD CLASSIC / MUSCLE MUSTANG , 73 OR OLDER MUSCLE CARS IN GENERAL. TURN KEY ONLY. TRAIL READY JEEPS , I would also consider trading up $25k over this package for modern Z06 manual trans only , very interested in 2019/20 Shelby GT350 , Trophy Truck !!!
NO PROJECTS, NO PROJECTS ,NO PROJECTS !!!!!!!!!!!!!!!!
pictures coming tonight 9/2/2022
LOCATION 48183
[email protected]
seven34-nine25-six118 Scott
LOCATION 48183
[email protected]
