1988 Mustang 5.0 AOD Transmission Complete Make offer
I have a complete Mustang AOD (1988) that I installed in my 90 CHP in '95 since the wife couldn't drive a T5 :angel:
For any automatic transmission I have had in any car or truck(Chevy and Ford) owned since 87 this AOD has been a rock solid beast and never let us down.
Prior to installing the AOD in my 90,I added a Baumann ReCal Pro AOD Valve Body Recalibration Kit and a Ford OEM "A" overdrive servo which clamps down on the overdrive band way way better than stock,it clamps so well in OD that when decelerating in traffic at 45 mph or less you must manually shift down to D out of overdrive.
The AOD is complete with the torque converter,Shifter cable,TV cable,reverse wiring harness,dust shields,flex plate,shifter(needs replacement indicator needle as it's sloppy & sun faded) and shifter bezel(has two small holes but does not effect the shifter).
A minor mention 2 bolts on the fluid pan are of a larger size but does not effect operation of the transmission nor fit ability of the pan.
Prefer local pickup over shipping due to what it'll cost to prepare and ship by FEDEX freight ($250)
Located in Richardson Texas(North of Dallas) $150 or best offer.
Post or PM with any questions,thanks for looking
