81 - 90 of 90 Posts
· Registered
Discussion Starter · #81 ·
Haven't had any updates for a little while. Been waiting on the wiring harness to get finished, and then once that's installed it will be towed over to my tuner.
I was told the harness should be finished within the next few days.
In the meantime, we got the 3 bar map sensor installed.
Also while we're waiting, we're swapping out all of the regular rubber vacuum lines and catch can lines with nylon air brake tubing. The lines will be cleaner looking, and won't collapse with vacuum and wont burst because of the psi rating.
Here are some photos of the new fittings going on in preparation of the lines.
Since the harness should be here soon, I should have more updates to go along with it.
· Registered
Very impressive build! What company or person did you send your harness to? Also, who are you going to have it tuned by? I'm also in TX (SE Texas; Beaumont area), so i'm not very familiar with the Austin scene. I do know some really good tuners in the Houston area if you haven't already decided on 1.
· Registered
Discussion Starter · #85 ·
Thank you!
The company doing the harness is LT1 Wiring. I found them online.
I have a tuner here in Austin that is going to be doing everything.
· Registered
Discussion Starter · #86 ·
Harness is being shipped back today! That took long enough...can't wait to get it in. Besides getting that installed, and making sure everything else is all buttoned up and ready to go, it's off to the tuner for the first startup!
81 - 90 of 90 Posts
