Well today I was going threw the parts list for the 92 302 roller build and I noticed I have bought a 1974 to 1985 timing cover kit with gaskets. Im just wondering how bad did i screw up not checking the years.. will this fit???
1985 Mustang
I think the only difference is that you have a spot for the mechanical fuel pump, and you'll need a block off plate if using an electric.
If planning to use it just give it a good look over as it may have a dipstick hole you would need to plug in addition to the mechanical fuel pump.
Perfect thanks man I already have the block off plate for it. Really appreciate the info
I'll definitely check soon as i get home.. i have a dipstick port in the back i may need to plug as well. Thanks
