I have a 19691Mach 1 428 CJ with a fresh restoration.
Fresh rebuild on an original 69 CJ Block bored 30 over with an Edelbrock Aluminum top-end and camshaft.
Bore 4.16, Stroke 3.98,
Head cc 72,
Deck clearance .020,
Piston dish 4cc,
Gasket thickness .030,
Compression ratio 11.0 to 1 approx.
Kit #Performer RPM Cylinder Heads, part # EDL-2044.
The kit came with:
Edelbrock Performer Aluminum RPM Cylinder Heads - 350-60069
RPM Intake Manifold - 350-7105
Edelbrock Performer RPM Hydraulic Camshaft - 350-7106 (.572 lift/296 duration)
MSD 8594 Distributor
Topped off with a Holley 750 Double Pumper Part # 4779-10 3129 (mechanical secondary).
THK 600 five-speed
3.50 gears in the rear
Strange 31 spline axels
Ford 9" Track-Lock
I have less than 1000 miles on this build.
A local engine builder put everything together for me and it runs great, but I'm having difficulty dialing in the carburetor.
It seems to run very rich, especially at idle. I can't find any vacuum leaks. The engine seems to idle fine at 850 RPMs.
I have tried adjusting the fuel mixture with a vacuum gauge and the max vacuum is about 10 in Hg at about 1/2 turn on the idle mixture screws, the engine is not very drivable at this setting. It leans out a little better but seems to stall at low RPMs under load. It runs better at 3/4 turns on the idle screws, but the carburetor runs rich (i.e. smokes at idle, smell fuel, black smoke).
The engine seems to like 3/4 turn on the idle circuit, but the driver doesn't like the black smoke at idle.
Initial timing is set at 14 deg TDC at 850 RPMs and 33 deg @ 2200 RPMs.
I have reviewed comments in multiple forums but haven't seen anything that has helped.
I saw one video published by Norm at Summit Racing. He has a video on Holley Carburetor Performance Tuning, suggesting drilling small holes in the primary throttle plates or adjusting the secondary throat plate position.
It seems Norm likes black smoke.
I want something more streetable. I'm not looking for a race tune right now.
I like old school, but I'm not happy with this tune.
I have been HotRodding for around 40 yrs. I have never seen this kind of problem before.
EFI may be looming in the future.
In this video Norm suggested, drilling 3/32 holes in the throttle plates adjusting the secondary plate open to lean out the fuel mixture?
I could try the secondary plate adjustment.
I have another old-school Holley on the shelf if I'm going to start butchering one by drilling holes in the primaries.
I'm not a fan of the possibility of unspent fuel coming out of the tailpipe or possibly washing the cylinders.
This will be fixed.
Any suggestions or comments are welcome.
Nice to see another 428CJ owner. I have a 70 Mach 1 428CJ car but mine is basically stock with the original carb. Reading what you have laid out the first thing I would do is drop two jet sizes in the primary and secondary and see what you get. I didn't notice you mention the jets hopefully I didn't miss it. But reading through it that is where I would start. Also you are positive you have the bowl floats set properly?
Jake
Hi Jake,
Thanks for the reply. That was going to be my next step. I met a guy at a local car meet with an O2 meter setup. We're going to try to change the jetting based on optimum O2 levels.
You will have to weld in a bung into the header or head pipe. But I think that is where you being thwarted. I look forward to hearing what you find.
Jake
Discussion Starter · #5 ·
Jake
I have shorty headers. It might be difficult to weld the bung above the collector flange. Would it be okay to place it slightly below the flange? I have 3' Borla Exhaust.
It depends on the machine your friend has. It will have to be able to take a reading from the exhaust to have any accuracy. A non heated unit element will need to be as close to the collector as possible. A heated collector can be installed several inches downstream from the collector. I would think there would be instructions with his machine with a recommendation. But yeah no matter what you will not install it in the header. It will be after the collector. Have you thought about just pulling 3 or 4 jet sizes and firing it up to see what its like?
Jake
