1 - 9 of 9 Posts
I need some tires for my new Bullitts and i can't deceide between 275/40/18 0r 285/35/18 on the rear. Give me some recommendations on tire sizes for front and back.
18x9's right?
I was running 285/40/18's and i just switched to 275/35/18's, they look much better that way and the tread contact on the ground is actually wider. :)
281NightCrawler said:
wider on what the 275s? If you have 18x10 I say get some 285s or 295s
The contact area of the 275's was wider than the 285's on my 18x9 rim. I am pretty sure he is running 18x9's, if they are 10's tell me where you got them. :D
I too would have like a little wider on the back (see sig). I was thinking of going to a 285 next time. It will be a while though (hopefully) because I just got these tires. Nice tires and not too expensive.
I was running 285's and like i said the 275's seem to look better and also are a bit wider on contact area.
You can get 18x9 bullits from Ebay or OE Concepts direct, and a bunch of other places. :) Check out an issue of MM&FF.
SonicBluGT said:
Ghost99, where did you get the 18 inch bullits?
I got them off Ebay from AFS wheels. Paid $910 in an auction few months ago and saw a set go for $690 :eek: wo days ago. For those asking they are 18x9. Ihave deceided to go with the 285's in the back and 265's up front in Falken 451's from onlinetires.com
1 - 9 of 9 Posts
