I hear all this, and I see it happen all the time, and then I look at my car, and I just don't get how it's possible :rofl:Been running 17X10.5 CCWs with 295-35-17 Hoosier A6s for a few years now on my stock fendered 1990 LX. Lots or variables from car to car but with some careful planning and tweaks it can work. In my case I run 1995 SN95 spindles, stock K-member, stock control arms, 10" coilovers, and CCW wheels with 6.75" backspacing. On the front I use a 3/4" spacer (to clear the strut) with just under 2.75 degrees of negative camber (that alone helps tuck it up inside the fender), trim the lower front section of the fender wheel opening and stretch out with a steel rod to provide clearance when the wheel turns in. On the rear I run fox length rear axles, a 1/4" spacer (to clear the inside wheel well), roll the rear wheel housing lip and some persuasive hammer work on the inside rear wheel well. It's a tight fit but it works.
No arguing with success. What spring rates are you running front and rear?
