1 - 17 of 17 Posts
I have 15x4 Weld Rodlights on mine.I had to do a little bit of grinding.I used a 1/4in spacer and the long shank lug nuts.
OK, here is the real deal. I have a set of Bogart 15 X 3-1/2 on my car. Your going to have to grind down the brakes caliper a little. And your going to need a spacer 3/4 in. The stock control arms make the wheels stick out and look ugly. So go ahead and go to a junk yard and get a set of 89-93 control arms and put them on. You might have to get longer 3" studs from Moroso. If you need part numbers pics and stuff let me know. I think I still have them somewhere.
US Army Retired
Discussion Starter · #4 ·
Let me guess. The smallest size wheel that you can run w/o grinding anything or using spacers would be a 15x5. What size of tire would you run on that?
Chris
I have 15x4 Centerline Convo Pros on my 95 GT and only had to grind a little off the caliper thats all. No spacer, no long studs. Fitment is fine also.
Chris,
I have 15x4 Convo Pro's on my 95 GT. PM me with a # if you would like to meet up and see them first hand.
David
Anyone running the pro star XP's they are supposed to be better for brake clearing....
I'm using Weld Draglites. They have the same hub as the Prostar. I had to grind on the caliper for clearance. It took all of 20 minutes to do. I tried going with the spacer route but it looked to "ghetto" for me. If you do a search you'll find a lot of info on the subject. Mine are 15x3.5".
What about the 13" Cobra brakes? Anyway to get the 15x4 welds to work?
ANyone have any pics with the ugly ass spacers on with welds? ;) (Ghetto or not, it may be my only hope. :( )
Thanks Bob. To be honest - I got tired of writing the same responses so I tried to cover everything in the writeup! LOL
Keith - here are some pics with the 7/16" spacer.
I *think* these are without the spacer.
http://schwarzmann.com/pictures/mustang95/projects/wheelsandtires/20021229frontoffsethigh.jpg
http://schwarzmann.com/pictures/mustang95/projects/wheelsandtires/20021229passwheeloffsetshigh.jpg
http://schwarzmann.com/pictures/mustang95/projects/wheelsandtires/20021229frontoffset.jpg
I still have my spacers if you decide you want some. I'll sell 'em pretty cheap. Moroso 7/16" spacers.
Great write up Jay!!
i run the 3.5" Prostars up front with 165x15" Pepboy specials.
It works, but i would like a tire that doesnt look flat all the time.
For my GT with stock brakes, i had to grind a 1/4 or so from the center of the caliper bar, which was a 1 minute job. Then i run a 7/16ths spacer behind each wheel.. Works out nicely, and the spacing looks righ on. Car handles just like it did with the 17" wheels ( although im not taking any 40-50mph highspeed corners)
1 - 17 of 17 Posts
