what is the difference and which would be better for my carbed 347 with an aod.
You don't get a choice. You have to run a 164t with the AOD. The difference between the two is size. The 164t has a larger diameter, thus a larger circumference. With more circumference comes the need for more teeth to maintain the same pitch in the teeth.
yup, what 88POSLX said.......The smaller 157t is generally used for the small bell housing with C4's.................
