My current iron head setup has 11:1 compression. Will mixing 110 Turbo Blue with 93 octane pump gas to get a 97-98 octane mix be enough to prevent detonation? I want to run as much advance as possibel. Thanks.
I got away with that for my 351-W 10.7:1 .
But the cam I designed only had a 106 lobe center, so it bled off a LOT of low end compression (where the knock usually occurs).
