1 - 9 of 9 Posts
After adding heads, cam, injectors, afpr, and having my intake ported my milage has dropped in half. Witch can be pretty pricey when running 92 octane on a daily driver. WTF some guys are getting better than stock milage after h/i/c upgrades.
I'm idling a little rich but that is normal with a 15511 cam and speed density. My fuel pressure is at 40 psi right now. I turned it down to 37 psi and went throgh the gears to red line and then parked it and plugs looked a little white. So I turned it back up.
I pulled 8 psi of vacuum from the intake witch I thoght was kind of low(22 psi with stock cam). I spayed carb cleaner every where and could not find a leak. I had an exta set of intake gaskets so I reinstalled my upper and lower intake any ways, but it did not make a difference. All the vacuum lines are were they should be and seam in good shape.
Do you guys think a mass air conversion would help my milage. The Crowler cam I'm running is speed density compatable but as mention above does idle pretty rich. Thanks for the help guys.
i face the same problem! i dunno if converting to M.A. is going to help because i have a 93. my gas mileage sucks ass. anyone that can help us out, duffman and i will bring over a keg of duff
Is that Hypertech chip supposed to be compensating for those 24# injectors? If you are idling rich, it isn't. If you didn't have the chip burned to exactly match your combination, you will have problems with bigger injectors on a speed density car.
On a side note, any cam that costs you low end torque causes the engine to work harder around town - hence, lower gas milage in that situation. You might try checking your milage on an open road trip. You might find that the before and after highway numbers are a little closer. Also, I've found that I can improve my milage by getting a little of the lead drained from my foot. Lead in the foot tends to build up after HCI installs. :)
Yeah. The chip will do wonders for gas mileage. My car got excellent mileage with the chip and H/C/I compared to stock and no chip. Mileage was actually much better than stock.
It's really simple... your MAP sensor is only seeing 8"s of vacumme so it thinks your always at part throttle & dumping in that much more fuel.
The vacumme that that the MAP see's is converted into a signal
for the ECA that interprits the "load" on the motor. High vacumme = idle low vacumme = part throttle or WOT. That is how speed density computer determine the enrichment....(that & a few other sensors :))
i think your real problem is a lead...in your foot that is. The less you press down the gas pedal the less you burn gas. A simple consept.
Well i'm 100% sure on a Speed Density car that only see's 8" of vacumme will send the gas mileage to hell in a $#!t coated handbasket in no time
Discussion Starter · #9 ·
The off the shelf chip has a more aggressive timing and fuel curve than the stock computer, but it was ment for a mostly stock car. With my h/c/i and 24# injectors, I increased air and fuel flow farely evenly, and I did not get any detination or lean out so I tried running it for a bit. Plus I ran my car with stock injectors for 2 weeks after my h/c/i upgrade and it still idled rich.
Today I ended up pulling the chip and reseting the computer. Performance did not seam to change, but the car is still idling rich. I will let you guys know if my milage has improved.
1 - 9 of 9 Posts
