i keep reading that the F-cam want's good amount of compression to work well in n/a applications.
10.4 enough on an iron headed car?
subscribing here id like to know this to as i am building a 10.5 comp. motor with the f cam and 1.7's also on a iron head
Yep, got the same setup here. Runs fine. Probally better choices out there but thats the cam i have, no complaints here.
See sig for setup.
Take care, Joe.
I am selling an f cam with low miles cheap here on the corral and it is also listed on ebay.
F cam is great on high compression naturally aspirated motors or low compression supercharged motors. Mine worked ok on a low compression N/A motor but that is why I am selling it-- because I would like to have a cam better suited to my combination.
Good luck with whatever you decide.
90lx351, nope, sorry man.
Used the et to hp conversion formula though.
FWIW, it said around 320 hp. I dont know how accurate that thing is though.
Hope that helps some.
Take care, Joe.
