why are the 03 Cobras clutch pedels so stiff, not that it is such a bad thing just curious. everyone i drove felt the same? i had a centerforce and aftermarket cable on my 96 and it was pretty easy. any input thanks!
Ford intentally did this so that you would build up your leg muscles so that when the inevitable happens and your car breaks down it won't be too hard for you to push it. Just kidding shane!:D
You realize you inspired that ?
What's up man how is it going over there. do you still project being home in Feb? later bro shane
PRESSURE PLATE
THEY INCREASED PRESURE PLATE PRESSURE ..WITH THE EXTRA HP THEY DIDNT WANT TO TAKE A CHANCE ON CLUTCH PROBLEMS..BUT I THINK IT WAS A LAST MINUTE THING AND THEY DIDNT CHANGE ANY PEADAL GEOMETRY.... THE 2001 Z06 HAD A PROBLEM AND IN 2002 GM CHANGE THERE PRESURE PLATE PRESSURE..FORD WAS COVERING ALL THE BASES WHEN THEY BUILT THE COBRA BEST THEY COULD
thanks!
yeah i read in the 5.0 or MMFF MAG THAT THE 03 made you use a little more effort to push the clutch pedal. later man thanks again!
