02 GT main wire harness connector question.
962 Views 2 Replies 2 Participants Last post by  Lightning777
Hi I have a 2002 GT, looking for help on the 3 connectors 2 grey, 1 black, that are on the passenger side footwell that plug in right next to the ECU. What do they do and maybe a pin out would be great. Going to try and post pic of them also
Thank you, Jon
Circuit component Electronic component Electrical wiring Electronic engineering Electrician
See less See more
Thank you, Jon
4
Sorry, hit enter too soon.
These may help. It looks like connectors C-210, C-214 and C-215 right by the PCM. As far as what they do, that is really hard. The service info isn't set up to reverse engineer from the connector. It's made for us to locate the connectors when we are already in the circuit we are fixing. Sorry. There are lots of circuits in there. Maybe all data or pro-demand has a pict with the circuits identified in each connector now that you know the numbers. Unfortunately Ford only shows the wire colors.
Good luck. Cheers.
Font Rectangle Parallel Pattern Number
Font Material property Parallel Rectangle Pattern
Font Rectangle Parallel Number Pattern
Font Slope Parallel Rectangle Pattern
See less See more
  • Like
Reactions: 1
