I am doing some research for a friend and have ZERO knowledge about the newer cobras. He wanted me to find out if there is a speedo correction gear necessary for switching to 410's or if it is reset electronically. Probably a stupid question, but like I said, I am ignorant when it comes to the newer cars.
Thanks in advance.
Dan
You will have to do it electronically. Either by a chip are a speed calibration devise
Get a speed cal from brothersperformance.com...$80 and you can make changes for tire size and gear swaps when needed...if you go chip, you'll have to get it reburned if the gears are ever changed...
Discussion Starter · #4 ·
Thanks alot for the help!
