If you plan on autocrossing more (and possibly making more mods based on your SCCA Category/class), I recommend using adjustable shocks & struts. Most non-adjustable aftermarket shocks & struts are stiffer than OEM shocks & struts. They move the limit of traction further IN, which means the car will be more likely to understeer/oversteer when pushed out on course. Your goal is to move the limit of traction further OUT. Adjustable shocks & struts allow you to dial out understeer and oversteer, and fine tune the suspension when you make mods in the future.
If I recall correctly, the Bullitt springs lower the car 3/4" relative to a stock GT. I wouldn't recommend going much lower than that when autocrossing a 79-04 Mustang with stock-style suspension (not coil-overs). Going too low will limit suspension travel, which will lead to understeer/oversteer when you push the car out on course. These cars tend to handle better when they sit higher than most people think looks cool.
As an example, I use Ford Performance C springs on my 1992 GT autocross car with Tokico Illumina 5-way adjustable shocks & struts. On most courses, I have the shocks & struts set at 2 out of 5 (5 is the stiffest setting). On tight courses, I soften the front struts to 1. Going stiffer than 2 in the front or rear makes the car handle worse.
If you ever have any questions about autocrossing your Mustang, please ask. I'm always happy to help. You might also want to check out my YT channel; I've been an instructor for several years and I made a bunch of videos about how to get faster out on course.
https://www.youtube.com/channel/UCOEWzAT17XoeGzSWysT1NXw/videos
