I have, undoubtedly reached that point in my life where I've been relegated to family hauling, which is actually a great thing in itself, but the vehicle I use for that purpose has left me missing the power I've become accustomed to. I picked up a 2000 Mercury Mountaineer with the 5.0L AWD drivetrain in 2015 and have put almost 55,000 miles on it - it has performed flawlessly with the mild updates I made to it and currently has nothing wrong with it at all aside from a minor rear main seep. It's time - for a mild doubling of power output and related reinforcement of the supporting parts (transmission, mainly). The main use is light offroad, mainly to campsites and carrying all the gear, including mountain bikes and/or ski gear.
The Merc is fairly well outfitted in stock form: latest iteration of 5.0L SEFI with GT40P heads, updated Cobra intake, very stout 4R70W transmission and 8.8 axle with 31-spline shafts, 3.73:1 gears and limited slip. While this is the only automatic shifted vehicle we own, I plan to keep it this way because the 4R really is that good a transmission! The one glaring issue with the setup is simply the exhaust. Few vendors supply quality headers for the vehicle (for obvious reasons).
Given the economic and supply chain circumstances of the day, I'm trying to use as many leftover parts from previous builds to perform the engine upgrade. Currently, short block is at the machine shop for inspection. This is what I've got planned:
I'm not sure what stall speed to size a torque converter for the truck, though... I bet the stock unit flashes somewhere in 1900-2000 RPM range and it seems like I'd want to flash a bit higher RPM for this new setup, but not sure how high to go.
- OE 5.0L block from my old '93 Mustang GT
- Stock crank with shotpeened and polished stock rods with ARP bolts, SpeedPro forged pistons w/metric ring pack
- Stock headers being replaced with TorqueMonster pieces
- Edelbrock Performer RPM II intake
- Looking at a set of my old World Products Windsor Sr. heads with 2.02/1.60 valving
- Beefed up spring pack for an aggressive Comp Cams Magnum grind
- Harland Sharp 4102 1.6 ratio roller rockers on 7/16" studs and guideplates
- Ported, polished, blended, port-matched to 1262 gaskets, no flow numbers yet, but will check
- Summit E303+ cam
